VCDS auto scan
mniceguy81
VCDS auto scan
Message par mniceguy81 »
Bonjour je une petite question concernen VCDS et les log :ced: , quelqun pu mes aider avec des erreurs VCDS ou me diriger dans la bonne direction. Merci (hello could someone please help with VCDS log errors or point me to the right direction. Thank you
mniceguy81
Re: VCDS auto scan
Voici le auto scan -
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 18 19 25 37 3D 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ5W021339 Mileage: 145090km/90154miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
3D-Special Function -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 BQ HW: 028 101 190 6
Component: R4 2,0L EDC G000SG 6254
Revision: 12345678 Serial number: VWZ7Z0D0123693
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 73EFC2D26B25
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 - - - Intermittent
Freeze Frame:
RPM: 924 /min
Torque: 98.0 Nm
Speed: 0.0 km/h
Load: 15.3 %
Voltage: 14.29 V
Temperature: 20.7°C
Temperature: 20.7°C
Temperature: 20.7°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023238
VCID: 3A712FF60CCF
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
Shop #: WSC 00000 000 00000
VCID: 68D5A5BE22E3
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000858733
Coding: 01898F020004200000120C000000000000
VCID: 40855D1E6A13
Part No: 1T0 955 119 C
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 00000
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 B HW: 1T0 909 605 B
Component: 02 AIRBAG VW62 0506 1400
Revision: 07023000 Serial number: 0037SD082ZDN
Coding: 0012338
VCID: 346D01CE2EAB
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000042
VCID: 30650DDEDAB3
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 871 A
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0003103
Shop #: WSC 11111 111 11111
VCID: 316308DAD1B9
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus - Intermittent
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
VCID: 2A511FB6FC6F
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 260010460306AE
Coding: 3D3F1349078002
VCID: 2757E682EF7D
4 Faults Found:
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:34
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:38
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:38
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 219
Mileage: 144915 km
Time Indication: 0
Date: 2000.00.00
Time: 15:33:56
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0812
VCID: 316308DAD1B9
Address 37: Navigation
Cannot be reached
Address 3D: Special Function
Cannot be reached
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: F4ED41CEEE2B
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 000 3201
Revision: 00H20000
VCID: 346D01CE2EAB
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No SW: 1K0 959 433 J HW: 1K0 959 433 J
Component: 01 KSG PQ35 G2 031 0308
Revision: 00031000 Serial number: 00000000000000
Coding: 99E800087F2D8505084F016001
Shop #: WSC 06550 995 81304
VCID: 377736C23FDD
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: F5EB7CCAE551
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
VCID: 2F670EA2C78D
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 30650DDEDAB3
End ---------------------------------------------------------------------
farnouche
Re: VCDS auto scan
Message par farnouche »
mniceguy81 a écrit :-------------------------------------------------------------------------------
Coding: 0000072
VCID: 73EFC2D26B25
1 Fault Found:
Freeze Frame:
RPM: 924 /min
Torque: 98.0 Nm
Speed: 0.0 km/h
Load: 15.3 %
Voltage: 14.29 V
Temperature: 20.7°C
Temperature: 20.7°C
Temperature: 20.7°C
voir module 17 (porte instrument)
Coding: 0003103
VCID: 316308DAD1B9
1 Fault Found:
capteur de température defectueux ou faisceau défectueux
VCID: 2757E682EF7D
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:34
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:38
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:38
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 219
Mileage: 144915 km
Time Indication: 0
Date: 2000.00.00
Time: 15:33:56
erreur de communication sur le bus CAN avec les differents modules
Coding: 0000048
VCID: 2F670EA2C78D
1 Fault Found:
moteur de fenetre arriere gauche mal codé?
le plus simple c'est d'effacer tous les codes d'erreur car certains sont intermittent donc sans réelle cause
ensuite apres un certains temps, tu refais un scan pour voir lesquels reviennent :wink:
tu peux aussi t'aider du wiki de roos-tech : http://wiki.ross-tech.com/wiki/index.php/Main_Page
mniceguy81
Re: VCDS auto scan
Merci Farnouche, Je sais pour la radio parce que j'ai enlevé et j'ai recherche l'adapteur pour la CANBUS qui est pour la radio Clarion VX401E et pour l'instrument j'ai comprend pas pourquoi ill faisant cela parce que cela fonctionne et pour la température également.
I know for the radio because i took it off and i'm looking for the CANBUS adapter for the aftermarket radio (Clarion VX401E) and for the instrument i don't know why it's doing that because it works and for the temperature also.
Je supprimerai les erreurs et le contrôle de DTC encore.
I will delete the DTC errors and check again.
mniceguy81
Re: VCDS auto scan
Voici les dernières erreurs du scan trouvées mais sur le dessus il indique qu'il y a un défaut de fonctionnement, pourrait quelqu'un me dire pourquoi et pour la radio c'est ok.
Here are the last scan af errors found but on top it says there is a malfunction, could some one tell me why and for the radio it's ok.
Sunday,25,September,2011,17:53:09:06299
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Mileage: 145110km/90167miles
01-Engine -- Status: OK 0000
17-Instruments -- Status: OK 0000
Coding: 0000072
VCID: 73EFC2D26B25
Readiness: 0 0 1 1 1
Coding: 0023238
VCID: 3A712FF60CCF
VCID: 68D5A5BE22E3
VCID: 40855D1E6A13
Coding: 00065493
Shop #: WSC 00000
Coding: 0012338
VCID: 346D01CE2EAB
Coding: 0000042
VCID: 30650DDEDAB3
Coding: 0003103
VCID: 316308DAD1B9
Coding: 0000011
VCID: 2A511FB6FC6F
VCID: 2757E682EF7D
VCID: 316308DAD1B9
Cannot be reached
Cannot be reached
Coding: 0000116
VCID: F4ED41CEEE2B
Revision: 00H20000
VCID: 346D01CE2EAB
VCID: 377736C23FDD
Coding: 0000116
VCID: F5EB7CCAE551
Address 56: Radio
Cannot be reached
Coding: 0000048
VCID: 2F670EA2C78D
Coding: 0000048
VCID: 30650DDEDAB3
mniceguy81
Re: VCDS auto scan
Je ferai un autre scan si tout est ok
I will do another scan to if it is all ok
farnouche
Re: VCDS auto scan
bin y'a plus de code d'erreur donc tout semble allez bien
il y'a neanmoins certains calculateurs qui ne sont pas accessible
peut etre du a la version 10.6.4
tente ta chance avec la version 11.8 beta sur le site de rosstech.com
mniceguy81
Re: VCDS auto scan
Ok merci farnouche j'essayerai
