voir module 17 (porte instrument)mniceguy81 a écrit :-------------------------------------------------------------------------------
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 BQ HW: 028 101 190 6
Component: R4 2,0L EDC G000SG 6254
Revision: 12345678 Serial number: VWZ7Z0D0123693
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 73EFC2D26B25
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 - - - Intermittent
Freeze Frame:
RPM: 924 /min
Torque: 98.0 Nm
Speed: 0.0 km/h
Load: 15.3 %
Voltage: 14.29 V
Temperature: 20.7°C
Temperature: 20.7°C
Temperature: 20.7°C
Readiness: 0 0 0 0 0
capteur de température defectueux ou faisceau défectueuxmniceguy81 a écrit :-------------------------------------------------------------------------------
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1T0 920 871 A
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0003103
Shop #: WSC 11111 111 11111
VCID: 316308DAD1B9
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus - Intermittent
erreur de communication sur le bus CAN avec les differents modulesmniceguy81 a écrit :-------------------------------------------------------------------------------
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 260010460306AE
Coding: 3D3F1349078002
VCID: 2757E682EF7D
4 Faults Found:
00380 - Special Vehicle Control Module (J608)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:34
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:38
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 190
Mileage: 144521 km
Time Indication: 0
Date: 2000.00.00
Time: 15:54:38
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 219
Mileage: 144915 km
Time Indication: 0
Date: 2000.00.00
Time: 15:33:56
moteur de fenetre arriere gauche mal codé?mniceguy81 a écrit :-------------------------------------------------------------------------------
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0201
Coding: 0000048
VCID: 2F670EA2C78D
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
