[VAGcom] Coming Home - Leaving Home: Automatique
mloft
Message par mloft »
Bonsoir. Pour ma part Coming-Home toujours pas opérationnel. J'ai trouvé d'autres sources d'infos, notamment celle-ci qui synthétise pas mal de manip. réalisable: http://forums.thecarlounge.netzerothread
Voici ce qui est dit précisément pour activer le coming-home en bas de page:
Enabling Coming Home/Leaving Home (CH/LH) on NA SE models, thanks RJB!!
The first step is to enable the convenience menu--see above.
Now, there are five places to verify in module 9 (central electronics). Use the long coding helper.
1. Byte 00/bit 5: assistance driving light & leaving home active--set this bit to 1 for active
2. Byte 00/bit 7: coming home active--set this bit to 1 for active
3. Byte 02/bit 4: coming home mode via--set this bit to 0 for personalization
4. Byte 21/bit 6: leaving home variant--set this bit to 0 for LH in LDS
5. Byte 23/bit 5: coming home logic--set this bit to 1 for new logic.
Once these coding changes are made, go into the convenience menu and select the lighting sub-menu. Here you will find coming home and leaving home settings. Select each and set the time in seconds (10 sec intervals) that you want the lights to remain on.
Once these changes are made, the functionality for a 2009 NA Tiguan SE with two-position light switch in the off position (factory switch--no need to change) is as follows. Unlock the vehicle with the remote--the lights will come on and remain on for the duration chosen in the convenience menu or until the vehicle is started. Upon arriving, turn off the ignition and if it is dark, turn off the headlamps. Remove the key from the ignition and give a quick pull to the lamp stalk--the high beams will flash. Upon opening the door, the exterior lights will come on. Lock the car with the remote and the lights will remain on for the duration selected in the convenience menu.
J'ai vérifié les paramètres 1-2-3 et 4, je les applique à la lettre, quand au 5éme, là j'ai choisi "0", autrement dit "old system" vu qu'apparemment c'est ce qu'il faut choisir pr se débarrasser de la manip "appel de phare", et bien ça ne fonctionne toujours pas.
J'ai listé également les défauts que pouvait subir ce contrôleur et est apparu qu'il y avait un petit défaut:
Info supplémentaire: 2K1955119C Wischer 010609 021 0501 1K0955559AH RLS 040609 054 0402
1 Code défaut trouvé:
02390 - Régulateur éclairage environnement (E400)
009 - Rupture/court-circuit à la masse
Capture:
Etat du défaut: 01111001
Priorité du défaut: 5
Fréquence du défaut: 1
Compteur de RAZ: 243
Kilometrage: 6096 km
Heure: 0
Capture:
marche
Tension: 12.35 V
marche
marche
arrêt
arrêt
arrêt
Je ne sais pas ce que ça veut dire, mais d'autres proprios auraient eu ce problème et chez eux le coming-home fonctionnait donc ça ne devrait rien à voir avec le problème de ce topic.
Toujours pas de proposition pour LDS? Quels sont vos réglages pour ceux que ça fonctionne?
[b]T[img]http://forums.funky-spirit.com/style_emoticons/default/horror.png[/img]uran[/b] [img]http://www.online-station.net/image_info/l_logo_fs.jpg[/img]
mloft
Message par mloft »
Hello.
Finalement happy end: mon coming-home fonctionne!!!
J'ai découvert ça hier par hasard: c'est qu'il faut vraiment rouler pour que le touran effectue un coming-home! Pas bête le toutou! Et comme moi je faisais mes essais uniquement en ouvrant puis en fermant la voiture via le plip du coup la fonction coming-home ne s'exécutait pas!!!
Franchement, vous auriez pu le dire! :P
Quel imbroglio ces réglages du toutou! Faut vraiment bien connaitre son véhicule! Je pense qu'en concession ils ne se prennent pas trop la tête... ils suivent une procédure et admettent que ça fonctionne. En plus, si la procédure est bien foutue, elle doit indiquer qu'une période de roulage est nécessaire pour que la fonction se réalise.
Enfin, personne pour la traduction de l'acronyme LDS? Apparemment, le LDS est le commutateur d'allumage-extinction des feux (là où on sélectionne le type de feux qu'on souhaite utiliser), voir:
0 = LH in LDS
Leaving Home immer aktiv auch wenn der Lichtschalter auf O (AUS) steht
Leaving Home is always active even when the light switch to O (is off)
1 = kein LH in LDS 1 = no LH in LDS
Leaving Home nur noch aktiv wenn Lichtschalter auf "Auto" steht
Leaving Home, only active when light switch to "Auto" is
Source: http://www.motor-talk.de/forum/coming-h ... 02354.html
mloft
Message par mloft »
Si plus personne n'a besoin d'infos, et si besoin est, je propose pour conclure (verrouiller) ce topic de récapituler les sources, les modifs à réaliser afin d'activer le coming-home.
OK :?:
passat cc waw
coming home leaving home
Message par passat cc waw »
bizour bizour aujourdhui jai vue jai vue que la fention coming home ne fonctioner pas sur ma passat cc pout tant jai dns ma touran jai pa hue a lactive elle etait activer dorigine si vou pouver mexpliquer comman vous avez reussi a l activer ca se reait extra mer6 d a vence
JE SUIS FOUE DE MA PASSAT
mloft
Message par mloft »
Hello.
Pour que la fonction "Coming Home" soit activable il te faut tt d'abord que les calculateurs soient présents, et donc que ta voiture soit dotée d'un minimum d'équipements (Pack City si je me rappelle bien).
Ensuite pour l'activer 2 solutions: soit tu as un câble VAG-COM et tu fais cela par toi même, soit tu passes chez ton concessionnaire.
@+ bonne journée
t0x1k
Message par t0x1k »
Re: coming home leaving home
passat cc waw a écrit :bizour bizour aujourdhui jai vue jai vue que la fention coming home ne fonctioner pas sur ma passat cc pout tant jai dns ma touran jai pa hue a lactive elle etait activer dorigine si vou pouver mexpliquer comman vous avez reussi a l activer ca se reait extra mer6 d a vence
il nous faudrait un minimum de renseignement sut ta passat CC , equipement , option
car en dehors du touran nous ne connaissons pas la gamme VW par coeur
maintenant sur une passat CC , les equipements devraientetre plus fournis que sur un touran
passat cc waw
bah bn soir cet une carat gris140 CH 2.0
ya tout sauf les Vitres surteintées
Caedes
Re: [VAGcom] Coming Home - Leaving Home: Automatique
Message par Caedes »
Toutes les touran 2007 ont-elles le coming/leaving home ?
Ou est-ce de paire avec les rétroviseurs rabatables éléctriquement?
Si non, est-ce toujours activable via VAG COM?
Qu'est-ce que ce genre de boitier : http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... K:MEWAX:IT
Merci pour vos conseils :)
Touran V3 gris poivre Trendline (Belgique) - CRTDI 1.6L 105CV BM6 - RNS310 - pack business - pack éclairage
MAD
Re:
Message par MAD »
Capture:
Heure: 0
Capture:
marche
Tension: 12.35 V
marche
marche
arrêt
arrêt
arrêt
Bonjour Mloft, j'ai essayé cet après midi de faire la manip et j'ai eu exactement la même erreur que toi, de plus j'ai remarqué que le menu retour/départ maison avait disparu de l'odb.
J'ai donc abandonné et tout remis à l'origine.
Peux tu me dire les codages exactes por avoir ce foutu coming home vraiment auto?
Merci d'avance.
MON PROFIL
C'est juste une modif minime à faire dans le module confort si je me souviens bien.
Il faut passer le CO/LO en "old" logic...
MAD
Message par MAD »
Merci Tomcat, je vais essayer ça.
MON PROFIL
MAD
Message par MAD »
Merci Tomcat, tu avais raison, juste une toute chtite case à décocher ds le module confort, et maintenant ça marche impeccable !
MON PROFIL
Je t'en prie, c'est avec plaisir ;-)
bato77
Message par bato77 »
Trop fort Guillaume!!!!
MAD
Message par MAD »
Une dernière petite question pour la route !
Est-ce que si j'utilise la fonction "réglage usine" dans l'odb, cela efface les paramètres modifiés avec vagcom?
Il me semble que quand le touran était neuf j'avais déjà le CH en auto et après quelques manip envolé le CH auto !
MON PROFIL
eagle 4
Message par eagle 4 »
Salut à tous, je vous met en lien mon topic sur le coming-home auto sur Tiguan.
Ce sera peut-être utile pour les nouveaux Touran qui vont sortir ! ;)
http://www.forum-tiguan.com/viewtopic.php?t=4135
Tiguan carat 2.0 tdi (170 cv) + pack techno + pack loisir + Mougkit bluetooth !! et enfin RNS 510 en firmware 2660 et Voice Control !!
207 Vti Sport pack
FZ6-N
Je n'ai pas du tout ce codage pour mon Touran 2009...
Dommage car le CH par les AB m'aurait bien plus !
MAD
Re:
Message par MAD »
Chides a écrit : En ce qui me concerne, mon touran est d'avril 2007 et le coming home / leaving home et automatique (pas de manip appel de phare à faire), lorsqu'il est, bien sûre, activé via l'ODB.
De plus, il fonctionne également même si le comodo de phare n'est pas sur Auto, sur 0 par exemple.
Alors moi depuis que j'ai programmé en "old logic" le coming home est bien automatique mais uniquement lorsque le comodo est sur la position auto.
Si je place le comodo sur la position 0, plus de coming home même avec "l'appel de phare".
Est-ce que ceux qui l'on programmé en old logic avec vag com, ont la même chose? TomCat? Mloft? Merl?
Merci et @+
MON PROFIL
Comodo
Message par Comodo »
Hello, j'ai bien colpris je pense la fonction "coming home", ca s'allume automatiquement lorsque l'on quitte la voiture.
En ce qui concerne la fonction "leaving home" comment allumer vous les phares a distance ?
En deverouillant la voiture a distance ?
@Comodo : Oui, c'est exactement ça.
@MAD : j'avoue ne pas avoir testé... :oops:
Modifié en dernier par tomcat92 le 05 sept. 2010, 11:17, modifié 2 fois.
MAD
Message par MAD »
tomcat92 a écrit :@Comodo : Oui, c'est exactement ça.
Ok :!: à l'occasion, tiens moi au courant :!:
MON PROFIL
MAD
Message par MAD »
Plus la peine, j'ai eu la réponse ce week-end.
J'ai regardé sur une Eos de 2007 d'un ami qui n'a jamais connu VagCom, son CH d'origine fonctionne exactement comme mon toutou en "Old logic".
Donc tout est normal...
MON PROFIL
MAD
Message par MAD »
Les feux s'allument quant tu ouvres le touran avec la télécommande et lorsque le capteur de luminosité détecte qu'il fait nuit. Et ce, quelque soit la position 0 ou auto du commodo.
:jok: Désolé les modos, j'ai essayé d'éditer mon message précédent mais je n'ai pas été assez rapide...
MON PROFIL
celman
Message par celman »
J'apporte juste ma petite contribution...
Sur mon touran 2005, je ne possède pas de capteur de luminosité et je peux quand même activer l'option.
En fait, vous laissez vos feux allumés, (l'alarme d'oubli des feux disparait) et vous quittez le véhicule. Les feux s'éteindront après 1minute automatiquement. :wink:
Par contre lorsque vous réouvrez à la télécommande, les feux ne se rallument pas automatiquement.
Utilisateurs parcourant ce forum : Ahrefs [Bot] et 1 invité
