RNS510 version B : sortie AV
Effectivement, j'ai aussi constaté cela 8)
La fiche est facile à trouver pour récupérer les PINS derrière le RNS, la question est de pouvoir faire le cable RGB à partir de ces PINS ?
J'ai fait une recherche sur VWNAVI, on parle d'un module RSE vendu par Kufatec, mais reste cher:
http://vwnavi.com/forums/showthread.php ... ght=output
Le RSE: Rear Seat Entertainment.
Tu vas google et tu tappes "RSE RNS510".
I want to add a screen also. Kufatec sells a OEM RSE kit, but it is very expensive. I believe I can build a setup for <$250 (incl screen). I haven't done it yet but this is what it looks like it will take -
VW parts -
7M0 937 711 - 26 pin connector housing (3B0 919 754 will work also, one is cheaper than the other and the only difference is the color of the plastic)
3x 000 979 010 repair wires, this will get you 6 total terminals, 1 each for R (pin 21), G (pin 8), B (pin 20), RGB Ground (pin 19), Sync (pin 7), Sync Ground (pin 6)
2x 000 979 010 repair wires if you want to use the audio out as well, you need 3 terminals, 1 each for R+ (pin 5), L+ (pin 18), NF- (pin 17)
Cabling -
I plan on using a 6 conductor shielded wire to run the video from the back of the 510 to under the passenger seat. If you want audio as well you would need another 3 conductor shielded wire for that. Ground the shields on one end of the wires to the car chassis or the 510 itself.
Video signal -
(This is really the only thing holding me back now) - I believe the video out of the RNS-510 is RGBs (RGB + Sync) at 15kHz. I've not found a automotive LCD screen that will take that as an input. So it looks like you will need a signal converter to convert the signal to composite or s-video. Something like this should work -
http://www.ambery.com/rgrgtotvcosc.html
Screen -
Add the screen(s) of your choice
J'ai lu le topic en entier et voici le produit que tu as besoin:
http://www.jncs.nl/winkel-filter.asp?aa ... gen&shop=5
Pour RNS510 version B uniquement.
180e.
Ici une enchère:
http://cgi.ebay.fr/RNS510-RNS-510-MFD3- ... %26ps%3D31
180e.
Ici une enchère:
En plus du TVFREE , est il possible d avoir un déport sur un écran aux places arrières avec un RNS 510B
VW?
la réponse est Oui , ci-dessous la réponse du marchant
Dans ce cas nous allons recevoir le module adapté d'ici quelques jours.
Il sera ajouté à notre site www.bc-elec.com et vous le trouverez sans doute d'ici une semaine en faisant une recherche sur RNS510
date 09/02/2009
Ps : il ny a une photo qq part sur comment démonter la console pour sortir le RNS510 sur les touran, j ai pas voulue forcer ce week end vue qu il est encore neuf
A Suivre
VW?
date 09/02/2009
A Suivre
Touran II 105cv
Interface RNS510 pour créer deux sorties auxiliaires A/V
voilà ,
Ce module permet de créer deux sorties vidéo et deux audio pour ajouter des écrans externes à votre RNS510 et leur transférer le signal vidéo et audio de votre RNS510.
NB: Ce module ne peut fonctionner que sur les révisions "B" du RNS510, si vous avez une mention sortie A/V dans votre menu.
prix : 169.99EUR modèle :RGB100
JE VAIS COMMANDER d autres seraient intéressé ? , çà nous permettrais de négocier le prix , je vais voir si il faut commander aussi le free TV du coup ou pas (car je ne sais pas si apres 10kmh l affichage externe se désactive aussi ou non ?).
http://www.bc-elec.com/ACCESSOIRES-AUTO ... ,8524.html
voilà ,
Modifié en dernier par boyezen le 16 févr. 2009, 10:39, modifié 1 fois.
Touran II 105cv
Cool
Ce qui m'interesserais de savoir, c'est si le RNS gère le Dual Zone.
En gros, mettre un DVD video sur les écrans externes pour les enfants à l'arriére, et devant, utiliser le HDD pour lire les mp3
Évidement :
-Son à l'arrière sur DVD video,
-Son à l'avant sur le HDD mp3.
Ça serait excellent 8)
Évidement :
Réponse OUI le dual zone marche c bon ca , les petits pourront regarder le dvd avec le casque pdt quon ecoute la radio ou MP3mougwai a écrit :Cool
En gros, mettre un DVD video sur les écrans externes pour les enfants à l'arrière, et devant, utiliser le HDD pour lire les mp3
Évidement :
parconte j ai un soucis je suis toujours en noir et blanc sur les écrans externe et j ai aucune doc que se soit que le module RNS510 ou les ecrans
t as une idée? (je dois avoir un soucis au niveau des normes NTSC PAL SECAM )
Arnaud
Touran II 105cv
Après pas mal de déboires avec BC ELEC. (je risque pas de recommander d'aussi tôt)
la sortie TV qui permet d'afficher le DVD sur des écrans externe fonctionne via le KIT RG100.
Je vous ai fait photos et vidéo dans sa version Bêta:)
la vidéo arrive sous peu le temps de la mette sur dailymotion
Arnaud
Arnaud
Touran II 105cv
pas mal comme installation,
juste dommage le prix de celui-ci vendu par bcelec, quand on voit les mêmes boitiers vendu 100€ frais de port compris...
http://cgi.befr.ebay.be/VW-MFD3-RNS-510 ... 7C294%3A50
ce serait bien de savoir un peu plus sur bc elec pour si jamais d'autre membre veulent commander quelque chose chez lui.
j'ai déjà eu contact avec lui pour un boitier multimedia pour mon mfd2. mais vu le pris et le manque de réponse a certaines de mes question j'ai préféré commander chez connex-video et tixxon.
enfin le principal c'est que maintenant cela fonctionne pour toi.
J ai bien installe le boitier, mais je bloque sur la connection qu il y a a faire pour l alimentation du boitier qui permet d avoir deux sorties externes video... A quels cables dois je les raccorder...
Je ne connais pas les couleurs du RNS 510, et j ai un peu peur de me tromper...
Ce serait sympa de me dire la ou les brancher...
d avance
d avance
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 6 invités
